September 25, 2026, 09:15:17 AM
Bolt Ons
The Only Header Thread You Should Ever Post In
11
15
Topic: The Only Header Thread You Should Ever Post In (Read 167192 times)
Re: Magnaflow or Dc headers+ Y-pipe?
Reply #120 on:
October 11, 2010, 12:38:38 PM »
Quote from: lavalleemike on October 11, 2010, 12:16:57 PM
I know Tim had multiple issues with his, and Dave (StricklyAccord) had to have his flex pipe replaced also. Those the the two guys local to me with the DC header, and they both had to have flex pipe replacements so I'd assume the issue is wide spread.
Thanks for the info mike. Now I know for sure. ...but I have no idea where to find comptech headers for sale
Reply #121 on:
October 11, 2010, 01:32:36 PM »
Quote from: Arielit0oo on October 11, 2010, 08:20:28 AM
Lol when I asked him abt it, he didn't remember him saying that and didn't know why he said that.
And I think he does know abt cars, hes a mod on acurazine.com, and is most likely gonna have the fastest all motor tl in the world, as soon as he hits the track
Just because he's a mod, doesn't mean he knows about cars. Anyway, like I said in my pm to you, I wouldn't know first hand about the DC flex pipe issue. Unfortunately, its a widely known issue in the Accord/ TSX community. I have no desire to go NA so that's why I still have the stock manifold on my car.
Reply #122 on:
October 11, 2010, 02:57:08 PM »
Quote from: CrackerTeg on October 11, 2010, 01:32:36 PM
Ok forget the mod status, he knows what he's doing. And looks like I gotta keep looking then, shits becoming a headache lol
Reply #123 on:
October 11, 2010, 03:03:21 PM »
I know quite a few people that have ad problems with the DC header flex pipe. Make sure your engine mounts are in good condition and replace them if they need it. I replaced my flex pipe twice. The first was the DC flex pipe and the 2nd was an aftermarket piece. I can't speak for the quality of the 2nd one, but I know it was done by a half ass shop, so they probably used sub-standard materials. The one I have on my car right now is made by Vibrant Racing, which has held up for a little bit. I guess it all depends on how much you're willing to spend. You could probably get a DC header and have a new flex pipe welded on for less money than a Comptech (CT Engineering) header for the TSX.
Reply #124 on:
October 11, 2010, 03:37:56 PM »
Quote from: timot_one on October 11, 2010, 03:03:21 PM
ill look into it then. All I really want is something that gives good power. Gotta keep looking...
Last Edit: October 12, 2010, 12:24:52 PM by Arielit0oo
dc header flex pipe leaking air..
Reply #125 on:
December 04, 2010, 02:49:20 AM »
Hey guys. I bought my dc headers not to long ago and the flex pipe is starting to leak air.
Where can I buy a new one for a good price? Thanks
Re: dc header flex pipe leaking air..
Reply #126 on:
December 04, 2010, 08:06:58 AM »
A new flex pipe or a new header? You should probably go to a reliable exhaust shop and have them re-weld a new flex pipe on your header.
Reply #127 on:
December 04, 2010, 11:47:17 AM »
Sry yeah, a new flex pipe, and thanks tim.
frostnyc
Reply #128 on:
December 04, 2010, 06:51:22 PM »
don't get a budget one... the flex pipe is a documented nightmare.
Reply #129 on:
December 05, 2010, 01:10:48 PM »
Quote from: frostnyc on December 04, 2010, 06:51:22 PM
What do you mean a "budget" one?
Reply #130 on:
December 05, 2010, 01:45:57 PM »
I think he's saying to not cheap out on the flex pipe if you get yours replaced. Vibrant makes good flex pipes.
Reply #131 on:
December 06, 2010, 12:19:22 AM »
Quote from: timot_one on December 05, 2010, 01:45:57 PM
ohh ok. thanks again Tim
Moessteezy
Names Moe
Exhaust setup
Reply #132 on:
August 06, 2011, 06:29:56 AM »
I was wondering if i got the dc ceramic header for my k24a4 will it bolt up with my future k24a2?
high flow cat? << What are my other options ?
Dual catback? or single?
personally i like the look of dual better. But i will choose performance and sound over looks.
Re: Exhaust setup
Reply #133 on:
August 06, 2011, 08:43:58 AM »
Since they are the same motor externally, yes it will bolt up. All K series headers will bolt up to all K series heads. The real difference between them is clearance with the chassis. You can get a high flow cat or a test pipe if you want, but I ran into issues with mine throwing a P0420 code for low catalyst efficiency. I had to get a defouler to get rid of the code before I kpro'd my car. If you like dual exhaust, go for it. Make sure you step down the diameter of the pipe after the split.
Re: Exhaust setup
Reply #134 on:
August 06, 2011, 09:23:52 AM »
Quote from: Moessteezy on August 06, 2011, 06:29:56 AM
Yup it will bolt up to any k-series head, headers are all interchangeable with the exception of some chassis specific ones which would only need minor modification to fit, DC sports are also known to have weak flex pipes so down the road you maybe replacing that just keep an eye on it (not an expensive fix), I recommend a higher flowing cat (maybe a magnaflo unit) bigger tubing (2.5" is a good size) and possibly a resonator if you want to cut back on drone, dual cat-backs will just add unnecessary weight for our 4bangers IMO but some people love the look so it's personal preference really
I'm personally going after a little more flow, going to 3" tubing,bigger hi-flo cat (to match tubing) and a longer resonator to quiet it down a little more (18" from 12" also with bigger inlets/outlets) and an apexi world sport 2 muffler to finish it off...it's gonna be loud but apparently the cops where I live only worry about if your muffler is a straight thru and if you removed anything from the stock system ie:cat and/or resonator learned this after getting pulled over and a warning for a burnt out light so I thought why not aha I read on k20a.org there is a tiny bit more power to be had by doing so but the 3" setup may not fly where your from (noise laws/emissions)
11
15
