September 29, 2026, 11:32:49 AM
Brakes
Broke my braided lines!?!? :(
Topic: Broke my braided lines!?!? :( (Read 16621 times)
another_person
November 14, 2009, 03:59:34 AM »
OMFG, worst Friday the 13th yet...I was stopped at a light and was holding down the brakes, and all of the sudden, no pressure...i'm like ok...thats odd...pump it a few times and still nothing. Luckily there was a parking lot near by, so I pulled in to have a look. I couldn't see any leaks on the d riverside, so I went around to the passenger side, it was raining earlier so it just looked like the wheel wells were wet, so I checked the master cylinder, and it was empty
I double checked the lines, and wiped them off and there was obviously brake fluid sprayed all over the passenger side wheel well. Upon closer inspection, the braids were all frayed and the tube was slit. Now I need to go find a new line
Re: Broke my braided lines!?!? :(
November 14, 2009, 11:45:32 AM »
That sucks.. You're lucky that you were at a stop light when this happened. This happened on a friend's car, but he was on a mountain and lost brake pressure on a straight. Next turn came up and he had no brake pressure. Luckily, he got out of it with only a few scrapes, but his car ended up in a ditch and totaled. He had SS braided brake lines also.
November 14, 2009, 01:14:29 PM »
what brand SS lines?
would emergency brake work if this happens to front wheels? supposedly rears should be fine since front brake lines should be separate from rears
November 14, 2009, 04:07:43 PM »
That sucks man. I'm glad nobody was hurt. Hopefully you can get this taken care of soon.
November 14, 2009, 07:38:01 PM »
wow friday the 13th sucks.. Don't worry I got pwned also... garage door scratch my bumper
another_person
November 15, 2009, 01:47:51 AM »
it was the ss line that came with the wilwood bbk. I don't know what it is, but for some reason, every single auto parts store in the area was sold out of braided lines and I think I've tried every other place I can think of, so I'll probably order a new one from fastbrakes on monday. E-Brake was the only thing stopping my yesterday, but the beeping was really annoying, but i'll take beeping over crashing...
November 15, 2009, 01:50:29 AM »
get goodridge SS lines, still didnt put mine on
November 15, 2009, 11:18:49 AM »
damn that sucks. i think thats the reason i wont go with ss brake lines. you have to keep an eye on them. luckily your ok though and you didnt crash your car.
InFuMoUs
November 15, 2009, 05:03:57 PM »
SS brake lines arent bad as you might think. I think it's how the Wilwood line was designed. I'm not sure if they've changed it, but the line arent made with the bracket attached to it to allow you to bolt it to the knuckle so when you mount the Wilwood lines it was exposed to the inner part of the wheel. Maybe that's what caused it to fray and split.
Steve -
Squad/
Team Crazy Creashunz
November 15, 2009, 09:13:58 PM »
Sucks man, glad everyone else is OK. My incident wasn't that serious. I was on my way to NYC a few years back when the washer in the Master Cylinder went. So I had to pump it to get pressure. Made it to NYC and back.
November 16, 2009, 08:26:31 AM »
Quote from: "InFuMoUs"
thats probably why.
my goodridge once have brackets just like oem once
another_person
November 16, 2009, 12:49:53 PM »
apparently, with the wilwood kit, you're suppose to rotate the bracket that holds the line to the car so that it moves it away from the wheels...I just talked to the guy at fastbrakes and he was like yea, you really need to rotate that so the line won't get near the wheels. I guess he should have put that in the directions...anyways, new lines on the way YAY
$65
booo
neoryan7
December 01, 2009, 04:42:35 PM »
Quote from: "another_person"
$65
booo
Good thing you weren't going downhill or something. I know SS lines are expensive. My Brembo BBK Goodridge line is 120 EACH
Kind of OT but does Goodridge sell only rear SS in a package or do i have to buy all four?
another_person
January 06, 2010, 02:25:38 AM »
Quote from: "neoryan7"
$65
booo
So after my car was put back together...the new lines only lasted until the end of the year...and this time I was going down hill...atleast I only curbbed one wheel, but yea, bad. I have no idea why the lines would chose to fray and get slicked now. Its been so many months without any issues. But I guess its time for the bbk to come off and the oem's to go back on. I'll go bbk again later, but for now, I'll just go back to stock.
January 06, 2010, 08:04:32 AM »
Who makes the lines? Have you contacted them about this? This is a pretty major safety issue and they could have a lawsuit on their hands.
