October 25, 2026, 06:04:09 AM
Author Topic: replacing valve cover gaskets  (Read 5966 times)
asnstyle22
asnstyle22 pfffft.
« on: November 08, 2009, 02:20:51 PM »
anyone know how to remove the gasket inside the 4 holes of the valve cover? i got extra valve cover to paint but i cant get those 4 gaskets out. i tried to do 1 of them by force and got most of it off but there are still bits stuck inside the small groove and i think i need to get it all out before i can place it with a new one or it will probably leak. any suggestions how to remove that little bit and how to remove the other 3? thanks!!
Reputation Power: 10
NVA-AV6 pfffft.
« Reply #1 on: November 08, 2009, 02:44:05 PM »
You don't, replace the spark plug tube seals, they are not build to be removed in one piece.
asnstyle22
asnstyle22 pfffft.
« Reply #2 on: November 08, 2009, 05:25:47 PM »
so... im not suppose to replace them? then why do they sell it as a set for the valve cover? and if i dont remove it as 1 piece, how can i remove it as smaller pieces?
NVA-AV6 pfffft.
« Reply #3 on: November 08, 2009, 06:01:45 PM »
If you don't have a seal puller take large flat blade screw driver and hamer them out from the top (not easy, but effective)
asnstyle22
asnstyle22 pfffft.
« Reply #4 on: November 08, 2009, 06:18:25 PM »
O... im suppose to hammer it out.. interesting... thanks for that info.
any ideas on how to get those little bits of gasket i have stuck in the grooves out? its pretty deep and the gasket seems sticky i have tried to use a screw driver to dig it out but its not working...
NVA-AV6 pfffft.
« Reply #5 on: November 08, 2009, 08:49:32 PM »
Sucks, but that is what I use......
InFuMoUs
InFuMoUs pfffft.
« Reply #6 on: November 08, 2009, 10:09:03 PM »
Try a screw driver where the tip looks like an ice pick.
EliteCM Profile
