September 25, 2026, 10:50:49 AM
25
26
27
28
31
Topic: The Only Fog Light Thread You Should Ever Post In (Read 265121 times)
Re: The Only Fog Light Thread You Should Ever Post In
Reply #375 on:
May 15, 2012, 10:07:18 PM »
Get out a DMM and test the wires. That's the best way to find out if I'm wrong.
Reply #376 on:
May 16, 2012, 01:35:18 PM »
When wired directly to the lighter the fogs will have power whenever the key is on ACC. That's how I wired mine up.
Reply #377 on:
May 16, 2012, 07:21:35 PM »
Quote from: pbplayer257 on May 14, 2012, 10:13:22 PM
are you sure the cigarette lighter is only on when the ignition is on? im pretty sure i used my phone charger when only the accessory was on..
edit: you said the blue wire is only hot when the ignition is on...correct?
Yup, well when your key is turned once in the ACC position. If I turn my car completely off the lights go off!
Quote from: Rushzer0 on May 16, 2012, 01:35:18 PM
^what this man said
Lolz
pbplayer257
Reply #378 on:
May 19, 2012, 10:53:52 PM »
What's the best way to wire my fog lights to turn on only when my low beams are on...besides splicing the headlight wire??
Reply #379 on:
May 20, 2012, 04:14:18 PM »
Keep in mind that the wiring is different for 03-05 and 06-07's.
Reply #380 on:
May 23, 2012, 09:19:26 AM »
Quote from: pbplayer257 on May 19, 2012, 10:53:52 PM
Follow the install guide for your year car. That's how they normally operate.
Reply #381 on:
May 24, 2012, 11:39:02 PM »
Okay so following the diagram below, it looks like the red/blk coming out of the switch is what is getting triggered to allow the lights to turn on. If I cut red/blk and run it to a +12V source (maybe ignition or I'll just find another wire that is hot with only ignition) my fogs should turn on with just the switch right?
EDIT: Will this affect the dash dimmer at all? Seems like that will also control the dash dimmer.
Last Edit: May 24, 2012, 11:43:24 PM by CYANiDE
Reply #382 on:
May 25, 2012, 09:12:37 AM »
With the 06-07 Accord, you must ground the blue wire if you want the fog lights to turn on independently of anything. The next step would be to find out which red/black wire goes to the correct pin on the switch so it doesn't mess with your illumination (the backlight for the fog light switch when your lights are on). I have never done an install on an 06-07, so I've never seen the switch, but it should be a 5 pin switch. Double check that first.
Reply #383 on:
May 25, 2012, 05:02:22 PM »
Quote from: timot_one on May 25, 2012, 09:12:37 AM
Why do I have to ground the blue out of the switch? Trying to understand it in terms of the circuit itself, cuz I didn't think it had to be grounded since that blue being grounded wouldn't that always meant he indicator would be on?
I'm going to pull the switch out and just pull out the red/blk cables and see which one makes the illumination go out then I know that its the other one lol.
Is this what it should look like after the modifications are made?
Last Edit: May 25, 2012, 05:48:31 PM by CYANiDE
Reply #384 on:
May 25, 2012, 10:56:09 PM »
Yeah. Pretty much. Look at the wiring diagram again and follow the blue wire. Where does it go? Do you know what that control circuit does? I do!
Reply #385 on:
May 26, 2012, 12:09:31 AM »
Quote from: timot_one on May 25, 2012, 10:56:09 PM
What does the control circuit do that requires the blue wire to be grounded? I'm just actually trying to learn how everything works, wiring it up is cake.
Reply #386 on:
May 26, 2012, 02:29:56 AM »
Basically, the control circuit will only allow your fog lights to turn on when your headlights are on, by providing ground for that relay. When your headlights are off, your parking lights are on or your high beams are on, the fog lights will not turn on if you have that blue wire still connected to the control circuit. As I said before, you must ground the blue wire or the fog lights will not work the way you want them to.
Reply #387 on:
May 26, 2012, 09:00:42 PM »
Quote from: timot_one on May 26, 2012, 02:29:56 AM
That definitely clears it up. (I'm majoring in Electrical Engineering so I always try to understand what I'm doing lol). Grounding that blue means you'll always have a complete circuit.
Thanks Tim!
Reply #388 on:
May 26, 2012, 10:30:09 PM »
Glad I could help Eric. Most people wouldn't understand why it needs to be done, nor do they care to understand why. The 06-07 is so much easier to mod the harness to have the fog lights come on with your parking lights. No soldering is required. All you need to do is ground the blue wire and you're done.
Fanitron
Reply #389 on:
July 15, 2012, 03:41:42 PM »
So after reading through this long ass thread I didn't see a post about this. (hopefully I didn't just miss it since my eyes are blurry now LOL). I'm in Canada so our cars come with DRL's, by default it is wired to the highbeam and is activated as long as the car is on and handbrake is released. My fogs are installed and fully functional as per default Honda wiring. What I would like to do is have my DRL work with my fogs
instead
of the highbeam and be able to still turn the fogs off/on once lowbeams are on. This is because once you turn on lowbeams, the DRL is deactivated so I would like to be able to use fogs in inclement weather. Thanks guys! (especially Tim, cause I'm guessing you're the one who's gonna figure this out for me
25
26
27
28
31
