August 12, 2026, 10:39:10 AM
17
18
19
20
31
Topic: The Only Fog Light Thread You Should Ever Post In (Read 259627 times)
yanks4life
Re: ASEAN/Inspire Fogs
Reply #255 on:
September 28, 2010, 07:20:01 PM »
where would i be able to buy me a set of ASEAN/Inspire Fogs lights it look so bad ass i live in CA. Near Inland Empire does any one know where to get them and installed here is my bumper
Reply #256 on:
September 28, 2010, 09:12:53 PM »
You can order replicas from Depo or anywhere online. As for installation, you can do it yourself or pay a body shop to do it.
Reply #257 on:
September 29, 2010, 07:10:47 AM »
What he said. Alex and Rolo had them on their 03-05 bumpers before they switched tto the 06-07 front end. Good luck getting ahold of either of them here. They went Casper.
Reply #258 on:
September 29, 2010, 04:11:49 PM »
Quote from: CrackerTeg on September 29, 2010, 07:10:47 AM
im still here fool..just lurking around. are you back in MIA? whats up
Reply #259 on:
September 29, 2010, 04:26:16 PM »
Damn! Back from the dead! I've been gone bro. I'm doing the mid east thing, remember?
Reply #260 on:
September 29, 2010, 05:16:39 PM »
Zing!
Re: Foglights on without headlights on 7.5 gen
Reply #261 on:
March 10, 2011, 10:59:56 AM »
Ok, so I want my fog lights on with just my parking lights. I've read about 8 different answers on how to do this and which wire to splice into, all producing different results, no results or fucked up results. Could somebody clarify this for me? Thanks.
Reply #262 on:
March 10, 2011, 11:01:12 AM »
Get with Tim... He is a wiring god!
Reply #263 on:
March 10, 2011, 11:06:23 AM »
Tim, I'm looking right at you. LoL. I would appreciate your expert advice on this. Thanks, in advance.
How To: Foglight installation video
Reply #264 on:
April 06, 2011, 07:57:06 AM »
Honda Accord Fog Light Installation Video
Hope this helps anyone, came in handy for me because looking at instructions not my thing lmaoOoo...
Last Edit: April 07, 2011, 01:30:08 PM by CrazyCreashunz
Re: How to: Foglight installation video
Reply #265 on:
April 06, 2011, 08:55:18 AM »
Good stuff Billy.
Reply #266 on:
April 06, 2011, 04:35:18 PM »
Quote from: timot_one on April 06, 2011, 08:55:18 AM
Good stuff Billy.
Why thank you.... Sticky please!
Tim I just have 1 question regarding that blue wire, if I connect it to the ignition wire under the dash will it allow me to turn the fogs on/off independently from the switch? I only want them on when I press the switch not when the the parking lights or low beams are on.
Another thing I saw you wrote and was wondering if this might also help in the setup I want having the fogs light up independently with the switch only...
"Do not connect the
white/
green
red
green
wires to the fuse box in step 15
Find the relay plug in the harness that has these four wires:
white/
green
red
green
blue
black
Cut the blue wire from the relay plug
Find the black/
red
wire in the underhood fuse box (fuse # 18)
Connect the blue wire to the black/red wire"
Now the wires that are bold and underlined do I just tape them up since they not in use? After I cut the
BLUE
wire from the relay plug and connect it to the black/
red
wire in the fuse box do I still connect the relay minus that blue wire? Do I still connect the
blue
red
wire to the 20 pin connector under the fuse box?
...maybe it was more than one question
Last Edit: April 06, 2011, 04:40:02 PM by CrazyCreashunz
Reply #267 on:
April 06, 2011, 10:36:00 PM »
FYI, you guys have different fog light wiring harnesses. You won't be able to compare notes.
Billy, are you trying to modify the wiring harness in the dash or the engine compartment? Nelson, same question for you.
These questions should have been posted in one of the
existing
fog light threads though. Time to research one of them and post your questions there. I'll edit this thread later and move the questions over to the proper thread.
Reply #268 on:
April 06, 2011, 11:25:09 PM »
Which blue wire do I cut and ground from the relay? There's like 4 for them. Thanks in advance. I removed my post from the other thread Tim.
Re: [REQUEST] Fog Light Mod
Reply #269 on:
April 09, 2011, 11:33:30 PM »
... stressed over this all!
Has anyone actually done the fogs as DRL's on here? If I connect the blue wire from the switch harness to the ignition wire what would be the best way to do so? Im iffy on touching that ignition wire
17
18
19
20
31
