August 08, 2026, 10:24:34 AM
Author Topic: MT fluid change (which oil to use)  (Read 15791 times)
Skippy pfffft.
« Reply #15 on: November 02, 2009, 10:26:49 PM »
I'll chime in on this topic.
Honda/Acura MTF was recently reformulated in the past two years.  If you want a definite reason, I can get it for you, but I personally do not know why it was changed.  I'm willing to bet they added some friction modifiers to combat the 3rd gear situation.  But still, I'm not sure that was the reason for the reformulation.  All new honda MTF has a white cap to signify it is the reformulated version.
About using other brands of MTF, it's all preference.  If you want to use it, it's your car, and I'm not going to stand in your way.  HOWEVER...if your car is under warranty (which most of ours are well out of by now), you can be denied coverage because you used aftermarket performance transmission fluids IF IT IS DEEMED THAT IT CAUSED A TRANSMISSION FAILURE.
I've used two brands of transmission fluid in the time that I've owned my car: Honda MTF, and GM Synchromesh FM.  Both are quality transmission fluids and I can vouch for the effectiveness of both.  I am not recommending that you use off-brand transmission fluid in your vehicle.  I recommend the use of Honda/Acura MTF because it was designed for the transmission and Honda/Acura have strict quality control specifications that the fluid used in the transmissions will not cause failures.  The same cannot be said about other transmission fluids.  Sure, all the performance people are going to say "but this is super racing rated 900% safe and will give you 140 horsepower to the right front wheel".  I don't care...it's not honda branded, and I don't use it.  I don't trust anything that wasn't made and endorsed by honda.  It's amazing that I considered using aftermarket brake rotors and pads....there was a time that I didn't even want to do that...
I'm not trying to say that I'm brand loyal, but I do try to cover my butt whenever I get the chance.  By choosing only HG fluids and supplies, I limit the amount of variables that my car needs to deal with.  I don't need to worry about juggling the maintenance schedules of 10 different fluids and enhancers, and I don't need to worry about future incompatibilities with new products or complications with old products meeting new ones....and if you sicko's are wondering....YES...I DO use Honda Genuine windshield washer fluid.
As for fluid change intervals, Paul is right on the money.  The book says every 30k miles.  That's good for your average driver that doesn't beat the hell out of their car.  If you're one of those (and I'm not pointing fingers because I'd rather not point a loaded finger at myself), change your tranny fluid at 15k intervals.
03 CM55 NBP 6MT
Reputation Power: 11
sherker55 pfffft.
« Reply #16 on: November 03, 2009, 12:27:52 AM »
shit
that's all I got
« Reply #17 on: November 03, 2009, 03:30:22 AM »
Guess its honda MTF until I get the TBS for the tranney fixed first. I am still in the process or transferring the extended warranty over.
« Reply #18 on: November 03, 2009, 08:45:30 AM »
have to go pick it up at dealership. have to change it when i change my oil. i only used honda MT oil, its not made by same manufacturer that honda uses for auto trany and engine oil. as far as i heard. honda has similar formulation to GM synthromesh. i didnt even buy amsoil synchromesh for trany oil
fabulous010 pfffft.
« Reply #19 on: November 03, 2009, 08:10:14 PM »
skip thanks for your advice and input on this. i didn't know honda reformulated their MT fluid. but i will try that first, if im not satisfied with it i might try GM syncro. as for the intervals i have never changed my MT fluid and im at 96km!!! better hop on this soon.
edit: just to go a little bit more in depth on what the manual says for MT and AT
normal conditions
MT: 192kms (129miles)  :o
AT: 192kms (129miles) or 6 years, then every 144kms (90miles) or 5 years.
severe conditions
MT: 96kms (60miles)
AT: 96kms (60miles) or 3 years, then every 48kms (30miles) or 2 years
« Last Edit: November 03, 2009, 08:22:19 PM by fabulous010 » Logged
hondaguy214
hondaguy214 pfffft.
« Reply #20 on: November 03, 2009, 08:14:27 PM »
i run penzzoil synchromesh in my 5spd trans. Haven't had any problems so far and i am happy with the shifting.
NECM SQUAD#6
Mr Eazy pfffft.
« Reply #21 on: November 04, 2009, 01:56:39 PM »
Anybody want to give this dumb dumb a lesson on how to change your own MTF on a V6 6speed?
Icebox pfffft.
« Reply #22 on: November 04, 2009, 02:21:29 PM »
this is for the i4 auto but shouldnt be too much different for u. http://elitecm.net/forums/viewtopic.php?f=9&t=156
« Reply #23 on: November 04, 2009, 02:36:31 PM »
Quote from: "Mr Eazy"
Searching owns you Arie. Found it in this thread in the v6 side of the house.
« Reply #24 on: November 04, 2009, 02:53:37 PM »
Damn.
fabulous010 pfffft.
« Reply #25 on: November 04, 2009, 06:37:06 PM »
looks like its similar to the 4cyls. you have to drain it from the bottom bolt. then refill using a pump, to pump back in new fluid. i think honda charges like $90 before taxes up here to do the change. im just gonna have them do it..
fabulous010 pfffft.
« Reply #26 on: November 07, 2009, 02:29:56 PM »
i had my mt fluid changed today with the newly formulated honda mtf. and it did make a difference. engaging 1st gear is alot smooter, and so is 2nd into 3rd. over all im happy with the results. maybe next i will get the corsport bushings..
sherker55 pfffft.
« Reply #27 on: November 07, 2009, 02:36:18 PM »
Quote from: "fabulous010"
how about the general knotchiness???
fabulous010 pfffft.
« Reply #28 on: November 07, 2009, 02:45:52 PM »
its slightly better. i like the feel of it for now. but i know i will get used to that too.
Pages: « First 1 [2]   Go Up
