October 04, 2026, 06:24:11 AM
Pages: « First < Previous 1 2 3 [4] 5 6 ... 10 Next > Last »   Go Down
Author Topic: What are your "go to" detailing products?  (Read 70644 times)
RTexasF
RTexasF pfffft.
« Reply #45 on: February 19, 2009, 02:35:32 PM »
Quote from: "stirfriedferret"
Hey, you guys were talking about Wet Paint.  I went to their site and read that it was a polish glaze.  So, I'm assuming it's a polish and a glaze, I may be wrong, but that's why I'm asking.  Is Wet Paint a polish, glaze, or a type of sealant?  I asked Tim and he said it was a sealant.  Some clarification would be nice :) Thanks.
It's actually an "all in one" product for lack of better terms. It will clean without marring and leave a layer of sealant behind for protection. If used on a clean surface with a buffer it will polish and remove minor marks, spider webs, etc. while leaving sealant behind. It's actually quite amazing as many here can attest to. I buy it by the case because (1) I go through quite a bit of it and (2) it's less expensive per unit.
I hope that answers your question.
Here are a couple of pics of what it can do safely. I did this by hand using about 1/3 more product than usual. No marring of the paint when done. Mind you this is an extreme example I did to show what is possible and extra care was taken. I've used the product for five years and know what I can & can't do. I'm not recommending others with less experience use it on a car this dirty. Sorry about the poor lighting but you get the idea.
« Last Edit: February 19, 2009, 02:45:21 PM by RTexasF » Logged
Rick, token old bastard.
« Reply #46 on: February 19, 2009, 02:39:47 PM »
Anyone like to split up a case with me?
RTexasF
RTexasF pfffft.
« Reply #47 on: February 19, 2009, 02:50:20 PM »
Get the combo pack if you order either single or case. A case would be six combo packs. Oh, it can only be ordered via their tool free number and no, I don't know why.
« Reply #48 on: February 19, 2009, 03:10:10 PM »
Can it be ordered on the web
RTexasF
RTexasF pfffft.
« Reply #49 on: February 19, 2009, 04:36:08 PM »
Did I stutter or something?
Kidding aside it must be ordered by phone and that's Mon-Fri.
« Reply #50 on: February 19, 2009, 06:23:32 PM »
I'm sorry I read that wrong the first time
RTexasF
RTexasF pfffft.
« Reply #51 on: February 19, 2009, 06:35:54 PM »
Not at all, I was giving you a little poke, just kidding brother. FOR ALL: You must call them to order.
« Reply #52 on: February 19, 2009, 06:59:58 PM »
Quote from: "RTexasF"
Rick, what product do you recommend for cleaning exhaust tips and with what kind towel/tool?
RTexasF
RTexasF pfffft.
« Reply #53 on: February 19, 2009, 07:07:00 PM »
Frankly any metal polish and some terrycloth towels that you can throw away when done (black city). Depending on how stained the tips are it may take several applications. If they are too far gone you can only expect to make them look better, not like new. If they are really awful then steel wool or aluminum foil can do wonders.
« Last Edit: February 19, 2009, 08:23:04 PM by RTexasF » Logged
« Reply #54 on: February 19, 2009, 07:18:48 PM »
looking better is better than leaving them dirty. thanks for the tip.
RTexasF
RTexasF pfffft.
« Reply #55 on: February 19, 2009, 08:24:45 PM »
Quote
I added this to the post above yours:
"If they are really awful then steel wool or aluminum foil can do wonders."  It might help.
« Reply #56 on: February 19, 2009, 09:16:25 PM »
Alright Rick what is the best product to try and remove a small scratch from glass? I've read a bit and know that if it's to deep its not possiable but, the one I have doesn't seem to bad.
RTexasF
RTexasF pfffft.
« Reply #57 on: February 19, 2009, 09:20:33 PM »
Never tried before so I googled this:
http://www.associatedcontent.com/articl ... glass.html
This may be the best or worst tip, I just don't know but it seems to make sense.
« Reply #58 on: February 19, 2009, 11:58:57 PM »
I'm in on that when I have the money.
Deep Gloss
Deep Gloss pfffft.
« Reply #59 on: February 21, 2009, 10:34:02 PM »
I always get asked what products I really like, if you want to read through my ramblings I  have included most of my go-to products below.. At the end of this I have included the url’s for the main shopping pages for the mfg of the products referenced. FYI: Surf City has free shipping and Duragloss have a flat $5 rate.
I have quite a few shampoos and in a pinch I have also went to the local Auto Zone and got some Meguiars Gold Class shampoo and it works great. My favorite regular strength maintenance wash is Durgloss 901/902.. The smaller portion is 901 the larger size is 902 – same shampoo.
For shampoo that is stronger, to strip old wax sealant of to ensure a clean starting point I will use Chemical Guys Citrus Wash & Gloss
I use a chennile micro fiber wash mitt like this (can be found at local stores as well)
http://www.chemicalguys.com/CAR_WASH_MI ... ic_493.htm
Glass Cleaner-Surf City  Clearly Better
Pre wash -treatment for paint and engine – it strips off old protection and cuts throughg grease = Surf City Grime Destroyer
Duragloss %501 to seal rims – makes brake dust wash off with no chemicals just soapy water.
Surf City Beyond Steel for regular duty rim cleaning
Danase Assasin Tire cleaner for heavy duty rim cleaning  but you have to be smart how you use  this because it’s HF acid based….
P21s Wheel Gel cleaner for cars with high end /braking components.
Surf City Tire Pro tire dressing… Not shine, just a deep rich matte black. It’s water based so no sling and it will not discolor the tires. As with all water based products, the longevity is not as long as silicone based products BUT those products sling and can cause the rubber compound in the tires to discolor.
Micro fiber waffle waves to dry
Micro fiber glass thief for windows (e-shine.ca)
A wet / dry shop vac with different crevice tool attachments, may as well get the heavy duty hose that is longer and thicker.
Interior trim cleaner, protectant, UV inhibitor, Aerospace 303 and Surf City Dash Away… Both are an AIO (all in one) product. Surf City is less expensive and in my observations perform the same.
To clean the heater core I use 1z Klima Cleaner
For leather I use Leather Master (3 step system) twice a year and then for regular maintenance (one step products) I use Zaino or Surf City with the latter being cheaper.
Any stubborn stains on exterior painted panels, faux chrome trim, chrome, stainless is Duragloss 501.. Just rub in into the area on concern, friction is good.. Obviously surface needs to be squeaky clean.
Stoners more shine to dress wheel wells.
Paint correction procucts below  to be used by machine & are listed in order of most to least aggressive:
[list type=]Meguiars M105 Ultra Cut Compund
Menzerna Power Gloss Compound
Menzerna Super Intensive Polish
Menzerna 106ff
Menzerna 85rd
3M Ultra Fina[/list]
Quick Detailer] In bulk, Finish Kare 425, in consumer sizes Surf City Speed Demon Detailer (carnauba based) or Surf City Hot Rod Detailer (sealant based)
I know most people just want to know what wax and sealant is best but to be honest the wax and/or sealant application is funny.. I can add Simonize or Turtle Wax to a car that has had the proper prep work and hat it will look better than a car with a coat of $30,000 Zymol Solaris…
I think I covered most of  the stuff that I use repeatedly and really can’t see being without..
Duragloss.com
Chemicalguys.com
Surfcitygarage.com
Detailersdomain.com(Leather Master Products & Menzerna ,   3M and 1z products)
Finish Kare 425: fk1usa.com
Pages: « First < Previous 1 2 3 [4] 5 6 ... 10 Next > Last »   Go Up
