August 13, 2026, 12:25:29 PM
Author Topic: inspire fogs installation  (Read 18651 times)
« Reply #15 on: October 20, 2009, 09:39:13 AM »
I have the same problem. My inspire fogs don't sit completely flush either.  I don't want to hack up my bumper any more so I just gave up.  It's not really noticeable to anyone but me so eh.
kaabob
kaabob pfffft.
« Reply #16 on: February 18, 2010, 04:28:20 AM »
So general consensus is 1) If you leave the jacket on and mount it, it will hit the subframe of the car?  I'm about to put my dupe Inspire fogs in and would love to know before I start hacking away =P
Btw, I have an 06' bumper, if that makes a difference...
Icebox pfffft.
« Reply #17 on: February 18, 2010, 09:33:15 AM »
Moved to appropriate forum.
wouldnt it make since to be in the headlight and other lighting forum?
on another note, i just got a set of these and hope i have more success with getting them installed in my 07.
Lemonjelly
Lemonjelly pfffft.
« Reply #18 on: February 18, 2010, 09:36:48 AM »
When I installed mine, I just made sure they were mounted VERY secure then popped the bumper on and pushed the inspires so the housing slipped under the sub frame.
You could cut away some of the top of the inspire jacket so that it doesn't hit anymore.
Also, mine aren't 100% flush either... My passenger side is perfect but on the driver side the right side (standing in front of the car looking at it) of the fogs stick out a little bit. Once the summer comes I will be fixing it because it drives me nuts, but for right now its fine.
Steve - NECM #4
ROLO pfffft.
« Reply #19 on: February 18, 2010, 09:57:27 AM »
They didn't make brackets.  They just cut holes and shoved the fogs in there.  They also have 03-05's, and you have an '06 right?
When I had the 03-05 what Tim said was right.. we just cut it and shoved the fogs in there... Now I have the 06-07 front which is much easier and safer... Lex dremeled all the space needed and he put a few tapping screws so the fogs don't fall out, extremely secure and steady.. You could PM him..
« Reply #20 on: February 18, 2010, 05:46:54 PM »
Quote from: "Icebox"
Yes, it would make sense to have it in the lighting forum.  Good call David.  Moved to the appropriate forum.
kaabob
kaabob pfffft.
« Reply #21 on: February 18, 2010, 07:44:48 PM »
Quote from: "ROLO"
I hope Lex didn't have subframe problems either. What's his online name? Sry, not too familiar with these forums.
k24low20z pfffft.
« Reply #22 on: February 18, 2010, 10:50:07 PM »
Quote from: "kaabob"
Quote from: "ROLO"
the reason that you are having that subframe problem is because you need to have the fogs in the right place on the opening of the fog before reinstalling the bumper. If you look at the fogs they have a pattern on the black plastic peice for that subframe metal part to slide in place..but before that you need to make sure your fogs are sitting flush in the pocket.. to get the fogs in all the way, you need to trim the two sides of of each pocket and all the plastic tabs in the inside of the pocket, what i did to secure mine an Rolo's was 2.. 1/2" self tapping screws on each top side of the fogs against the plastic from the bumper on top of the fog light opening.
kaabob
kaabob pfffft.
« Reply #23 on: February 19, 2010, 12:30:24 AM »
Ah sweet, thanks for the advice!  I've cut off the 4 tabs in the inside of the pocket to temp place ebay fogs right now, but you mentioned that I also need to trim both sides of each pocket to accommodate the Inspire's... will look into that before I remove the bumper.
« Reply #24 on: February 19, 2010, 09:55:37 AM »
I don't even remember where the hell I originally moved this thread to. Mustve been one of my confused days.
Reputation Power: 11
sherker55 pfffft.
« Reply #25 on: February 20, 2010, 11:14:25 PM »
why can't there be any Inspire fogs that just fit right in with no issues, what is so hard about making that happen!
« Last Edit: February 21, 2010, 10:02:44 PM by sherker55 » Logged
« Reply #26 on: February 21, 2010, 11:44:36 AM »
You could get an Inspire or ASEAN front end and they will fit no problem.  The issue is that you're trying to use a fog light that was not intended for the bumper.  When that happens, you can run into problems.  Any modification has it's challenges.
Pages: « First 1 [2]   Go Up
