November 05, 2026, 12:25:30 AM
Pages: « First < Previous 1 ... 5 6 [7] 8 Last »   Go Down
Author Topic: [Profile] Rich01  (Read 116357 times)
« Reply #90 on: January 01, 2015, 09:15:37 PM »
We are back home now. Had to exercise a lot of restraint  Grin especially when this Genesis Coupe pulled up next to me and down shifted trying to get my attention. Car's running great. It does have a drone at certain rpms under load. May have to look at a better exhaust option later on.
Reputation Power: 10
NVA-AV6 pfffft.
« Reply #91 on: January 02, 2015, 07:39:57 AM »
I'll take a closer look at it when we get home and am putting in the grommet.
Once again, excellent work Paul. Thanks for everything, I'll hopefully have the engraving done next week. I have to see if the machine is tied up or not
After engraving and filling of the engraving I would throw a few wet coats of duplicolor engine clear coat on it....
« Reply #92 on: January 02, 2015, 08:47:30 AM »
Good call. I'll get a can.
« Reply #93 on: January 09, 2015, 08:41:13 PM »
So today I got to experience the LSD in the snow. I have to say that I'm impress with how the car handled, even with the increased torque and starting off in first gear.
NVA-AV6 pfffft.
« Reply #94 on: January 10, 2015, 07:54:38 AM »
Nice having 2 wheel drive in the snow isn't it...
« Reply #95 on: January 10, 2015, 06:31:20 PM »
Damn it now I want a lsd for my car.
« Reply #96 on: January 10, 2015, 07:02:53 PM »
Yes it is Smiley
Yes you do  Grin
« Reply #97 on: February 16, 2015, 09:56:59 PM »
Think i may have to brave the cold one of these days to trace down some fuel issues.  Best case i find something with the regulator plumbing, worst case i have to pull the mani to check the injectors.
To rule out the tune, i went back to the original Cal that Paul loaded and it still has an issue starting after a hour.
« Reply #98 on: April 01, 2015, 08:21:40 PM »
Progress tracking using VDyno software. This is being used to solely as a means to track gains. Each VDyno run is being done in as similar condition as possible. I'll try to do the same when I put it on an actual dyno. The dyno results will then be compared to the VDyno results so all results can be adjusted accordingly. Results from a dyno maybe lower or higher than VDyno, but from what I've seen, it should be pretty close.
Base after tuning
J36 so far
« Last Edit: April 01, 2015, 08:32:06 PM by Rich01 » Logged
« Reply #99 on: July 28, 2015, 09:43:01 PM »
It was 90* with 70%humidity. I was sweating my balls off loading calibrations lol. There maybe another video somewhere out there taken by the owners buddy, but here's one I took. The others, I had my fingers in my ear. Between the exhaust, intake and rollers it was deafening.
https://www.youtube.com/watch?v=3kVnmPNSdHE
« Last Edit: July 28, 2015, 09:48:48 PM by Rich01 » Logged
« Reply #100 on: July 28, 2015, 11:57:03 PM »
That's why I bring ear plugs or some sort of hearing protection when my car is on the dyno.  Wink
« Reply #101 on: July 29, 2015, 07:17:17 AM »
Happy with those numbers?
« Reply #102 on: July 29, 2015, 12:41:59 PM »
I had no expectations really, so yes.  We wanted to compare cals. to see best readings instead of doing it on the street. I also have a street log from the same time to compare to the virtual dyno that I've been using. On a side note, according to the Internet, if I add 12-15% to the Dyno Dynamics readings I'll  have Dyno Jet readings so that's 310+whp.
« Reply #103 on: July 30, 2015, 02:11:12 PM »
I think that people assume that all dynos read the same. That's just not true. Even two dynos from the same manufacturer that have been calibrated properly won't read the same. People use dynos as a dick measuring device instead of a tool to measure changes in the tune/parts bolted on.
« Reply #104 on: July 30, 2015, 02:34:32 PM »
Exactly. I'm not a number whore. The car pulls hard and will eat my tires if I'm not careful. I'm happy and like to surprise the hell out of people when I hit the gas lol.
Pages: « First < Previous 1 ... 5 6 [7] 8 Last »   Go Up
