October 24, 2026, 06:37:43 AM
Author Topic: Power Steering Fluid Leak?  (Read 10510 times)
CYANiDE pfffft.
« on: September 26, 2009, 09:30:04 PM »
Went to get my oil changed today and the mechanic noticed that there was oil under the car. We left there assuming it was engine oil and were going to wash the engine bay and take the car back on Friday to see what was up. When we got home, me and my father decided to do some further inspecting, and we now speculate it's power steering fluid. The level of the fluid appears to be right on the line still, but I honestly don't recall what level it was prior to that so I can't say it has stayed the same.
I took a picture and show where some fluid is leaking and I'm 90% sure it's power steering fluid since there is a hose connected from the PSF container to this part.
What is this part called? (Part Circled) Is there something inside that can be easily repaired, like a rubber washer or something?
[Sorry about the cell phone picture quality.]
The area circled is where the leak is coming from, from where those two parts join together. I really hope that's the only place that's leaking but we'll continue to check and take the car back next week anyway just to make sure there also isn't an oil leak.
Reputation Power: 10
NVA-AV6 pfffft.
« Reply #1 on: September 26, 2009, 10:01:54 PM »
See my post on V6P......
« Reply #2 on: September 26, 2009, 10:16:58 PM »
#20
If you're not losing power steering fluid, then it's not leaking from your power steering pump.
CYANiDE pfffft.
« Reply #3 on: September 26, 2009, 10:50:11 PM »
Quote from: "NVA-AV6"
Thanks!
This good. I can't say I'm not losing power steering fluid because I don't remember if it was at more than the maximum level since I don't think I checked it. (Irresponsible I know). But fluid is leaking from there, it should be power steering fluid correct? Also thats the exact diagram for my model/year etc?
CYANiDE pfffft.
« Reply #4 on: September 26, 2009, 11:37:15 PM »
Nevermind, it is the one for my car. Thank you!
« Reply #5 on: September 27, 2009, 01:04:12 AM »
No problem.  Take Paul's advice and keep an eye on your PS fluid level.  If it goes down, you may want to replace that o ring.
CYANiDE pfffft.
« Reply #6 on: September 27, 2009, 09:45:29 AM »
It's really cheap so I am replacing it anyway. I hope that fixes my problem. No other fluids should be coming out of there correct?
« Reply #7 on: September 27, 2009, 12:35:18 PM »
No, you should not be leaking any fluids from your PS pump.
CYANiDE pfffft.
« Reply #8 on: September 27, 2009, 01:00:51 PM »
Alright. I was also told that my belt looks like it has been in contact with the power steering fluid. There's gunk on the "rollers" so I need to clean that and get a new belt put in.
« Reply #9 on: September 27, 2009, 06:42:04 PM »
If there is no damage to your belt, you can clean it and save some money.
CYANiDE pfffft.
« Reply #10 on: September 27, 2009, 06:50:40 PM »
Well the "rollers" (What's the technical name for 'em?) that the belt goes around, the smooth sides have some melted rubber on them and the belt does appear worn. I am going to fix the leak first before I go and replace the belt.
« Reply #11 on: September 27, 2009, 07:22:00 PM »
They are called pulleys.  If your belt is damaged, cracked, or worn out, replace it.
CYANiDE pfffft.
« Reply #12 on: September 27, 2009, 07:48:32 PM »
Belt looks worn out on the right side like shown in the picture. The pulleys have rubber melted onto them so I'd also need to clean that up before putting on the new belt. Trying to see if I can go tomorrow to get that O-Ring.
CYANiDE pfffft.
« Reply #13 on: October 03, 2009, 12:06:58 PM »
Got the O-Ring and replaced it. Took about 2 minutes. I tightened it extra tight this time and so far so good. Will check it throughout the week to confirm. Thanks for all the help everyone. Once I am sure that the leak has stopped, I'll be cleaning the engine bay and replacing the belt.
