September 26, 2026, 08:12:31 AM
Author Topic: Re: Torsion Mount Bolt-On  (Read 3668 times)
NWINNIE34 pfffft.
« on: September 23, 2009, 12:46:57 PM »
is this the same as an Ingalls Stiffy Kit (Engine torque dampener)?
http://cgi.ebay.com/ebaymotors/INGALLS- ... dZViewItem
heard these make a nice difference
« Reply #1 on: September 23, 2009, 01:37:53 PM »
A self-contained elastomeric shock that mounts on brackets between the engine and the chassis. It reduces extreme engine movement and dampens the motion, providing many benefits:
- Greatly improved off-the-line acceleration
- Reduced wheel hop
- Improved vehicle stability
- Reduced shock loads on driveline components
- Smoother shifting
- Reduced wear on exhaust system joints
- Less vibration transmission to the driver compared to polyurethane motor mounts.
- Less shock load, compared to torque straps and chains.
- Drifting – helps reduce shock loads when wheels gain traction.
- Reduces motor movement – decreases the chance of motor parts rubbing against the hood and frame.
Ingall's "STIFFY" Engine Torque Damper
« Reply #2 on: October 18, 2009, 09:26:16 PM »
Like everyone else has said, it sounds like an Engine Torque Damper.  The owners claim sounds a little bit fishy to me.  You only mention that it was connected to the PS engine mount, where was the other end of it connected to?  Did you see this on an Accord?  Did you take pictures?
