August 05, 2026, 06:58:38 PM
Detailing
Foam Gun?
Topic: Foam Gun? (Read 13626 times)
Foam Gun?
September 23, 2009, 11:41:20 AM »
I'm looking for a good foam gun but I want to keep the price under $100. It definitely needs to hook up to my hose, not a power washer. I've been looking at these:
http://autogeek.net/auqufofogun.html
http://autogeek.net/pifofowagun.html
http://autogeek.net/woqufofogun.html
http://www.amazon.com/exec/obidos/ASIN/B000Y190WE/ref=nosim/autopia-forum-20
They all look pretty similar. Any recommendations?
Re: Foam Gun?
September 23, 2009, 07:15:31 PM »
Try hitting up Skizot or Deepgloss I know they both employ a foam gun when doing there washes so they may be the best to ask.
RTexasF
Re: Foam Gun?
September 27, 2009, 02:33:37 PM »
Those that work off of a standard hose are just okay from what I have seen. The real thing is powered by a pressure washer and produces serious foam (but costs serious money). I haven't used either just stating what I have read and from pictures I've seen.
Rick, token old bastard.
Re: Foam Gun?
September 27, 2009, 07:36:40 PM »
I have the Gilmour one that I got from Scott. To be honest, it's better than nothing. I would recommend that you just save your money and buy a pressure washer and get a foam gun for that instead. Like Rick said, they produce foam and are a good chunk of money. They are a lot better than the foam guns you are looking at though.
skizot
Re: Foam Gun?
September 28, 2009, 09:48:27 PM »
There is a difference between a Foam GUN and a Foam CANNON. A foam gun is something similar to what you are looking at. They work well with a standard variety garden hose and the cheapest place to get them is from Amazon.com. About $40. A Foam Gun will soak down the car pretty good and rinse away any loose dirt/debris, as long as you do a good after rinse with as strong as a rinse available to you.
Now a Foam Cannon is a totally different beast. You would first pressure wash the car, then soak it with the foam cannon, which requires a pressure washer and a total setup can run over $250 if you factor in the cost for the pressure washer too. The foam it creates is very thick and will cling to the car much longer then what a foam gun will produce, which in turn is able to loosen and soak away (or should I say rinse away) more dirt/debris, leaving less chance to scratch the car when you finally put a mitt to it, hopefully using a 2 bucket wash.
Re: Foam Gun?
October 10, 2009, 09:39:53 AM »
do search on amazon. i seen couple good once for under $50 on there for hose with bras fittings and everything.
http://www.amazon.com/Gilmour-75QGFMR-F ... 944&sr=8-1
Re: Foam Gun?
November 11, 2009, 10:31:28 AM »
I'm pretty sure I'll be picking up this one soon.
http://www.amazon.com/Gilmour-75QGFMR-F ... 351&sr=1-1
Any recommendations on what kind of soap to use with it? I typically use Meguiar's gold class car wash soap.
Re: Foam Gun?
November 11, 2009, 12:36:40 PM »
I've been using
Surf City Pacific Blue Wash & Wax
with mine. You can use the Meguiars stuff that you have and get the same results though.
Re: Foam Gun?
December 01, 2009, 09:36:04 PM »
Quote from: "ikethegreat"
its good soap. just buy it in galon bottle. more cost effective
i just picked up CG super suds 2, galon for $20 i think
Re: Foam Gun?
December 02, 2009, 08:31:42 AM »
I finally put in the order for a foam gun yesterday. Expected delivery is mid-January! There goes trying this baby out before it gets too cold to wash the car. Oh well.
I picked up a gallon of DP Xtreme Foam Formula Auto Shampoo from that dude skizot to use with it.
Re: Foam Gun?
January 09, 2010, 05:46:54 PM »
Hello from Amazon.com.
We're writing about the order you placed on November 30 2009 (Order# 103-3660886-6629068). Unfortunately, we are unable to ship the item(s) as soon as we expected and need to provide you with a new estimate of when the item(s) may be delivered:
"Gilmour 75QGFMR Foamaster Adjustable Multi Ratio Cleaning Gun"
Estimated arrival date: February 17 2010 - March 08 2010
Re: Foam Gun?
January 09, 2010, 11:42:58 PM »
That sucks man. At this point, it would just be a snow gun anyway. Maybe this is a blessing in disguise?
DetailedImage.com
Re: Foam Gun?
January 10, 2010, 12:25:41 PM »
Sorry to hear that. Gilmour shut down a plant and they haven't shipped an order out for months. I placed an order in October and I still don't honestly know when it will be here. Every time I call them it sounds like it's a couple of more months away and the story changes. The good news is we still have the Foamaster II (
http://www.detailedimage.com/Gilmour-M33/Foamaster-II-Foam-Gun-P210/12-Gallon-Tank-S1/
) in stock, although it's a very limited supply. If you want to guarantee yourself one you can order from us now. Don't wait too long though, we're getting a lot of inquiries from people who are buying from us because most places are out of stock. We also have two package deals I'll list below. I highly recommend the Foamaster II Starter Kit. Let me know if you have any questions.
http://www.detailedimage.com/DI-Package ... -Kit-P367/
http://www.detailedimage.com/DI-Package ... -Kit-P368/
Greg @ DI
Re: Foam Gun?
September 13, 2010, 11:25:44 PM »
found foam cannon at home depo for under $20 if you have powerwasher
