September 25, 2026, 07:52:37 AM
[REQUEST] How To: Ingalls Front Camber Kit
Topic: [REQUEST] How To: Ingalls Front Camber Kit (Read 4981 times)
September 16, 2009, 10:48:28 AM »
Has anyone installed the Ingalls front camber kit before? I'll be installing this weekend since my camber is off. Trying to find a DIY but no luck since 7gens dont need them on the front. Thanks guys.
Re: [REQUEST] How To: Ingalls Front Camber Kit
September 16, 2009, 06:25:22 PM »
JEREMY, STOP
***** WARNING IN CAPS FOR A REASON*****
DON'T DO MY MISTAKE, DO NOT INSTALL THE FRONT CAMBER KIT. OUR RIDES DON'T NEED IT AND IT WILL BE A PAIN IN THE ASS.
LIKE A DUMB FUCK I INSTALLED MINE AND NOW I REGRET IT.
But, if you do decide on installing them, let me know how much you want for the OEM balljoints, I would rather buy them from a fellow member than getting them from my suppliers.
September 16, 2009, 06:32:21 PM »
Thanks for the heads up Arie, but I actually hit a monster pothole and knocked my camber out of alinlgnment, my right front is off by -1.2 degrees
September 16, 2009, 06:45:26 PM »
Quote from: "slipkord"
no doubt bro, just remember me when you have the extra parts
September 16, 2009, 06:54:40 PM »
Arie you have PM
September 16, 2009, 08:20:14 PM »
Looks like I'll be making my own DIY, sweet!!
jobata23
September 17, 2009, 01:28:43 AM »
arie, i think there is a solution on that, you see the ingalls front camber kit long and its not the same height as the oem ball joint. If you get the spc version, its shorter like the factory, so i just bought another set of spc the front camber kit on my car to replace the ingalls front since the rubber boot is torn on the driverside, so ill give you guys a feedback when i get it installed.
September 19, 2009, 06:49:33 PM »
I wasn't able to take out the stock ball joints. Will have to take it to a shop. Although after install of the supercup kit I think I might of had a bent strut causing the camber to be off.
My steering wheel would shake under normal braking. I thought it was warped rotors. But after install of my suspension it has stopped. I'll get another alignment to see if that was the culprit.
