April 25, 2026, 07:58:51 PM
What GAS do you put in your ride?
Topic: What GAS do you put in your ride? (Read 24082 times)
September 02, 2009, 07:28:19 PM »
Well basically I been using Hess and putting in Premium 93 Octane since I purchased the car in January 2008. Would it harm the car if I switched to Regular 87 Octane or should I just keep putting in the 93? It's like a $10 difference on filling the tank this is why I am asking...
Re: What GAS do you put in your ride?
September 02, 2009, 07:33:58 PM »
I usually go to Walmart because I've got one of their gift card things that gives $0.03 off a gallon and get regular 87 octane. When not using that card, I just go to a nearby Pix (Publix gas station). I very rarely put premium in my car, maybe every 3 months.
September 02, 2009, 08:15:46 PM »
I generally use premium.
September 02, 2009, 09:01:55 PM »
E-85
September 02, 2009, 09:45:32 PM »
Kroger Premium(93 Octane) every time.
September 02, 2009, 10:23:32 PM »
You guys are friggin' crazy. Costco 87 octane and call it a day. Save your money, the 4-cylinders aren't optimized to take advantage of the extra octanes.
September 02, 2009, 10:27:31 PM »
E-85 = 105 octane
September 02, 2009, 10:34:24 PM »
It only cost about $2.00 extra and i dont pay for my gas so I figure why not unless it hurts it.
September 02, 2009, 11:08:15 PM »
If you guys read your manual you will find that the I4 is designed to use 87 octane gas.
September 02, 2009, 11:18:42 PM »
Quote from: "MyNameIsThien"
E-85
is that safe to run in our cars?
September 03, 2009, 12:14:40 AM »
I can. I have an AEM FIC to adjust the amount of fuel I put into it. You can't without any fuel management.
September 03, 2009, 02:20:03 AM »
Quote from: "k24low20z"
E-85
With fuel management and a proper tune, you can run E-85. Some people change fuel injectors and fuel lines as preventative maintenance, although not absolutely necessary in some cars. Some cars will need new injectors and new lines though.
September 03, 2009, 03:07:29 AM »
I though u can't use ethanol because it will eat up the rubber hoses because I search and found a lot of E85 conversion kits.
September 03, 2009, 08:08:27 AM »
E85 will damage certain hoses. I'm not sure what our cars have though. You must have hoses that will not deteriorate from the E85.
I run 93 because that is what my car is tuned for. I've been running 93 ever since I've been on k-pro. Before that I normally ran 87.
September 03, 2009, 09:40:05 AM »
Premium 93 octane from day one.
