July 01, 2026, 01:59:40 AM
question about retrofit
Topic: question about retrofit (Read 5901 times)
najeezy
August 31, 2009, 03:54:14 PM »
im checking out theretrofitsource.com, and i was checking out complete kits.
the complete kit includes:
Projectors
clear lens upgrade
OEM ballasts
OEM Philips 85122+ D2S bulbs
Shrouds
low beam relay wire harness
if i already have a hid system with ballasts, bulbs and a wire harness, i should only need the projectors, clear lens and the shrouds correct? or only the bulbs included fit the projectors? someone halpz me :]
InFuMoUs
Re: question about retrofit
August 31, 2009, 04:15:37 PM »
What kind of HID system you got? For the low beams (9006)? If so, you cant use those in the projectors. The projectors use D2S type bulbs.
Steve -
Squad/
Team Crazy Creashunz
Lemonjelly
August 31, 2009, 04:18:24 PM »
if you have a PnP hid kit for the oem headlights the bulbs will not fit. The oem lights use 9006 bulbs and the projectors use D2S bulbs.
since you already have the ballasts, and wire harness you would just need to order the projectors, clear lens(optional, not necessary for a retrofit), bulbs, shrouds, and a set of AMP to D2S ballast adapters
http://store.theretrofitsource.com/product_info.php?cPath=26&products_id=97&osCsid=6b7d803947e24ccca50494da21eb1221
Steve - NECM #4
najeezy
August 31, 2009, 07:30:38 PM »
yeah i was talking about the 9006 bulbs.
dang, so that means i have to buy the ballast adapter and the bulbs as well as the projectors and shrouds -_______-
thanks for the help guys
JC04accord
August 31, 2009, 07:46:41 PM »
I've got a pair for FX projectors and lenses I can sell to ya as well as many pairs of D2S bulbs.
InFuMoUs
August 31, 2009, 09:26:15 PM »
Quote from: "najeezy"
Looks like it, but in the link I noticed you can get the ballast adapter free if you buy the other parts from them. I just briefly skimmed thru it so you gotta check.
Steve -
Squad/
najeezy
September 02, 2009, 11:34:55 PM »
just wondering, is there anyone in the socal 909/626 area that has experience with retrofitting?
September 04, 2009, 11:10:51 AM »
Not anyone that I would recommend.
