June 24, 2026, 11:20:14 AM
HID bulb replacement for conversion kit
Topic: HID bulb replacement for conversion kit (Read 5762 times)
JulsV6
August 28, 2009, 11:14:54 PM »
Any suggestions on brand and type of bulbs to get to replace my bulbs in my HID conversion kit?
had them installed for less than 6 months and now driver side has turned yellow...I'm assuming it has gone bad and is time for replacement...I was looking at PIAA brand, but have no idea which one is best to be used for my situation. Any advice or suggestion would be appreciated.
JULIE
MDVACM Squad #11
07 WHITE AV6 COUPE
06 GREEN/BLK KAWASAKI ZX6R
Re: HID bulb replacement for conversion kit
August 29, 2009, 12:07:48 AM »
i can sell you a brand new set of HID aftermarket bulbs for $45 shipped and the color temp i suggest is 6k.. but i have every bulb size in stock in every color...
JulsV6
August 29, 2009, 12:19:12 AM »
i'm still trying to find the contact info of the guy that sold me this kit...b/c im sure it still has warranty on it. i'm going to check with a few of my guys on my squad..they also bought theirs from the same guy on gen7a....if not we'll see. i'm wondering if its possible to buy the replacement bulb at any local shops here in the DMV area. I can live with the it for now, b/c it still works its just annoying to see two different colors. but i originally had 8000k
JULIE
MDVACM Squad #11
07 WHITE AV6 COUPE
September 04, 2009, 11:14:37 AM »
So wait, you're looking for replacement HID bulbs or you're looking for replacement halogen bulbs?
September 05, 2009, 07:55:49 AM »
+1
September 05, 2009, 09:26:27 AM »
Sounds like she's looking for replacement HID bulbs for the plug and play kit she has installed. From what I've seen, all them HID bulbs sold on egay have the same connectors and will replace what you have with ease. HTH.
September 05, 2009, 10:20:35 AM »
it looks like she needs a new set of bulbs...she said one of them is starting to fade.
JulsV6
September 09, 2009, 09:32:23 PM »
I might just buy a new kit to replace it because someone mentioned to me that it may be a bad ballast causing the bulb to no longer output the HID color, the reason why that one side is the color of the OEM lights after several months.
JULIE
MDVACM Squad #11
07 WHITE AV6 COUPE
JulsV6
September 09, 2009, 09:33:44 PM »
but thanks guys for your responses
JULIE
MDVACM Squad #11
07 WHITE AV6 COUPE
