January 28, 2026, 11:27:45 AM
Detailing
Good drying products
Topic: Good drying products (Read 19015 times)
RTexasF
Re: Good drying products
August 08, 2009, 09:05:49 PM »
I suppose that is good advice for some but it has never worked for me. I have tried everything under the sun as a "drying aid" including Aqua Wax. None has ever worked well for me so I refuse to use it while the car is wet........just doesn't work for me.
In all honesty I think all of the multiple presure/foam washes you describe is just plain bullshit. I realize that is what some of the "Pros" do but I have never found one single advantage in doing that extra work........it's more for show than go in my opinion. On the other hand I have never done a $100K Prancing Horse Car either but I've done more than my share of Caddys, Mercedes, Audis, Corvettes, etc., NONE required all that extra crap just to wash the car......and yes I tried it. Advantage? ZERO! A TOTAL waste of time in my mind. I'm going to clay then compound/polish the car after it is washed anyway so why should I treat it like a baby's ass?
? I just don't get it. If you think that is better for your high dollar Porsche then go for it......to me it is wasted time and money. What works for some doesn't work for all.
Rick, token old bastard.
August 08, 2009, 10:16:06 PM »
Quote from: "RTexasF"
I don't know that what you use is as important as
how
you dry the car. For the last rinse remove the nozzle and starting at the top flood the car with water on all surfaces working your way down. You'll see that the water flows off of the paint unlike when you use the nozzle. Give it a few minutes for the water to run off. If you have a leaf blower that's a great way to get the water out of seams, mirrors, etc. Then DAB at the remaining drops instead of rubbing them dry. If you are using an absorber, microfiber towel, waffle weave, or chamois the procedure should be the same. I have some WW towels that I thought were high quality and they scratched the shit out of the paint. Rather than light the fuckers on fire I decided to use them exclusively on windows.......works like a charm. Now I use a regular MF towel to dry but DAB the areas as opposed to "rubbing the car down". Try it.
+1 on the advice of using the hose without a nozzle to let the weight of the water pull the drops off the car, leaving very little to actually dry. +1 on the leaf blower to get the rest of the water out of all the hard to reach places, exactly what I do. You want to avoid rubbing or touching the paint unless absolutely necessary. Hence why when you wash the car you should pressure wash, soap, pressure wash again, before ever taking a mitt to the car. The only thing I would add to RTexasF's advice, is that as a drying agent, you can use your favorite quick detailer to help where you dab your MF. This way you are still having some sort of lubricant between the MF and the paint, but ultimately dry to a clear and debris free shine.
Using the hose method to dry the car works if you have access to a hose. Unfortunately, not everyone does, including me. That's why I'm planning to get a leaf blower to help dry the car.
August 09, 2009, 01:36:38 AM »
Chamois works decently, but listen to Rick though. I have been using a microfiber waffle towel to dab my car down after leaf blowing it for quite some time.
RTexasF
August 09, 2009, 09:26:21 AM »
Quote
You would be a prime candidate for Optimum No Rinse, called ONR on the detailing forums. You only need about two gallons of water. It works, leaves a gorgeous shine with very little water, no marring, and no blower needed.
skizot
August 09, 2009, 10:07:57 AM »
With a lighter color car, I would agree, with a darker color car, every little bit of potential debris on the car open up the potential for unnecessary swirl marks.
I agree that if you are going to clay/polish the car afterwards, it seems a bit unnecessary, but for in between times when you are not doing the full monty so to speak, then for me and my peace of mind, I would rather know the car is pretty darn clean, before ever touching the car with a mitt or MF. Porsche paint is very soft, so it can be a pain in the ass to maintain.
As for the drying agent, I might make a recommendation if you have never tried the stuff, my favorite QD is by Finish Kare (aka FK1) is it their 425 series QD. If you have never tried the stuff, I would recommend it. Both my cars (one silver, one deep dark blue) respond well to using this during the drying portion of cleaning the car. Keep in mind that by the time I am drying the car with this stuff, there is maybe a few droplets of water here and there and some fine mist, otherwise the car is pretty dry at this point, so I am probably closely mimicking how you use a QD as well. Anyway, I agree, what works for one, does not work for the other. For my Silver Accord, I never go through the added hassle of pressure washing, foaming, etc. I just rinse and wash. Then again, even under direct light, it is very difficult to see all the swirls and scratches. The Porsche dark paint, that is a totally different story.
August 09, 2009, 02:58:54 PM »
Quote
I actually already use ONR. I love the stuff, it works really well. For those weekly washes, it does an awesome job. But once in a while, I like using Megs Gold Class Shampoo and the hand pump garden sprayer(not the best, but it isn't bad either).
RTexasF
August 09, 2009, 04:34:32 PM »
Quote
I agree with what you say when just a wash & wipedown is needed on especially sensitive paint, that makes sense to me. I've done a few BMW's with paint that got marked up just looking at it wrong but had just flat forgotten about them. :grin:
August 12, 2009, 01:14:13 AM »
These are all much appreciated suggestions. For those curious about the "sham Wow", I've never used it, but I have a similar type of drying cloth called "The Miracle Clothe" or something of that nature sitting in my garage, but have hesitated to use it because it just feels too gruppy and stiff to touch the paint with. The leaf blower idea was presented to me some time ago, but again, I hesitated on this method because I heard that small gasoline particles pass through the air from the leaf blower, and these can damage your paint over time (although this is probably a really slim to none occurence). I do, however, own an air compressor that has a trigger nozzle attachment which works just fine for getting water out of hard-to-reach areas.
I also do sheet the water from top to bottom, and that method works well. Another good drying agent is the Mr. Clean car cleaning system because it filters the water into a fine mist as a final water coat. It sucks that I've produced swirl marks on my dark paint from drying in a circular or back-and-forth motion, so maybe I'll start dabbing now and see how it goes.
One quick side question: I'm washing my MF towels as we speak. I remember reading that you should add vinegar or something to the wash load. What's the purpose of this??
--Dave--
NECM Squad
Profile & Mods List
2003 I4 Accord Sedan
RTexasF
Reply #23 on:
August 12, 2009, 08:24:07 AM »
The idea of adding vinegar to the final rinse is that it helps release any remaining wax or products in the towels. I have never done it so I don't know if it actually works. It is also supposed to help keep them soft.
Reply #24 on:
August 12, 2009, 09:24:20 AM »
i use water to dry my car when i have the time
http://www.youtube.com/watch?v=VtoWk9thSEI
Deep Gloss
Reply #25 on:
August 12, 2009, 02:12:22 PM »
how
Rick is 100% corect!
Deep Gloss
Reply #26 on:
August 12, 2009, 02:15:54 PM »
how
Damn... Our conversation really abosorbed didn't it!!! Good deal!
Deep Gloss
Reply #27 on:
August 12, 2009, 02:25:43 PM »
Intial pressure washing kicks off loose debris with mechanical agitation with a mitt.
When you shoot a thick layer of foam onto the car it will cling to the panels and then the weight of the foam will makes it fall to the ground. While the foam is clinging it emulsifies some of the left over debris that didn't come off during the initial pressure washing. Once it is emulsified some of it then falls with the dripping foam to the ground
The secondary pressure washing then blasts off anything that was emulsified but wasn't pulled to the ground by the weight of the foam.
Sure, if you are going to compound and polish anyhow I can see how some may think it is worthless but when you are striving for 100% perfection and zero swirls/micro marring, why take any chances in creating more work? After I get 98% of the swirls out I often have to do multiple polishings just to get that ONE DAMN isolated scratch out and I sure would be pissed at myself if I was the one that created all that extra work.
The small amount of time it takes in preventing any additional swirls pays for itself during the correction phase. Plus you end up removing less clear coat should you instill the defect.
RTexasF
Reply #28 on:
August 12, 2009, 07:42:41 PM »
I don't doubt that at all but would never go to that much trouble. In truth I don't go for 100% perfection down here. With the clientèle here in Northern Mexico if you can get $250 for an 8 hour detail you got a fat hog by the ass! They do SUBURBANS down here for $45!!!!!!!! That's hand wash, hand wax, clean carpet (not just hoover), clean glass inside & out, goop up the trim......$45!!!!!!!! Is it the kind of work you or I would do? Of course not but the locals here are so used to that, and pleased with the outcome, that they pass out when any amount over $50 is mentioned. If I can average $25 per hour I'm doing well. Different world down here.....not to mention things like today's heat index was 108º.
skizot
Reply #29 on:
August 12, 2009, 09:45:08 PM »
I don't doubt that at all but would never go to that much trouble. In truth I don't go for 100% perfection down here. With the clientèle here in Northern Mexico if you can get $250 for an 8 hour detail you got a fat hog by the ass! They do SUBURBANS down here for $45!!!!!!!! That's hand wash, hand wax, clean carpet (not just hoover), clean glass inside & out, goop up the trim......$45!!!!!!!! Is it the kind of work you or I would do? Of course not but the locals here are so used to that, and pleased with the outcome, that they pass out when any amount over $50 is mentioned. If I can average $25 per hour I'm doing well. Different world down here.....not to mention things like today's heat index was 108º. :grin:
