August 12, 2026, 05:18:08 PM
Pages: « First < Previous 1 ... 14 15 [16] 17 18 ... 39 Next > Last »   Go Down
Author Topic: [Profile] timot_one  (Read 367397 times)
« Reply #225 on: December 02, 2011, 07:40:18 AM »
If I didn't have a j, I would say I want one of those.
Rushzer0 pfffft.
« Reply #226 on: December 02, 2011, 08:12:14 AM »
Nice list of parts!! Since your going with a port and polish, are you going to get the supertech valves oversized at all? Like 1mm or anything? And what boost levels will you be running?
This thing is gonna be strong as a tank Cheesy
Icebox pfffft.
« Reply #227 on: December 02, 2011, 09:44:58 AM »
if i were you, i would definitely upgrade the timing chain since you are going to be putting down so much power.
« Reply #228 on: December 02, 2011, 10:45:36 AM »
I hear ya David.  That's why the Toda timing chain is on the maybe list.  I think that the timing chain and oil pump chain are going to be moved over to the final parts list.  It's a tough pill to swallow to spend over $400 on 2 chains.  The good thing is that I already have the Hybrid Racing tensioner.
Austin, there's no plan to go with oversized valves at the moment.  I'm going to talk to the guy that's going to be doing the porting and polishing to see what he suggests.  I wasn't planning on having a valve job done, but it may be an option.  The good thing is that I haven't bought the valves, so if I want oversized, it won't cost me anything extra.  I can't be sure about the boost levels I'll be running, because I don't know of anyone that's running the SC I'm going to upgrade to on a K24.  I do know that on a stock K20 with a 3" pulley, the MPx90 can make about 19-20 psi.  On a K24 with a ported head will probably be a bit lower around 15-16 psi.  Anyway, it's not about the level of boost, it's all about air flow.  I'm hoping to make around 400-450 whp and about 300-350 tq.  I'm not totally sure that is going to be possible though.  We will see after it's built and tuned though.
All the little stuff adds up though.  I'm planning on replacing a lot of hardware too, which is going to be costly.  I also need to set some money aside for the Hybrid Racing 74mm throttle body.  I spoke to Competition Clutch yesterday and it seems that I'm going to be at the limits of my Stage 4 clutch.  That's why I'm planning on getting their Hyper Single.  I just want to see if I can convert over to the Tilton hydraulic release bearing.  If not, I'll be getting just the Tilton master cylinder and a new OEM slave cylinder.
B.R.03EX pfffft.
« Reply #229 on: December 02, 2011, 12:05:03 PM »
 Huh? Wow, thats going to be amazing once you finish it.
ADI
ADI pfffft.
« Reply #230 on: December 02, 2011, 12:11:01 PM »
Wow very impressive list you there Tim, I am excited to see the numbers make   Smiley
i just looked at the Magnum Powers MPx90 Supercharger, very impressive stuff....  and its made to fit already.
« Reply #231 on: December 02, 2011, 04:54:49 PM »
Sounds expensive but very impressive cant wait to see that beast on a dyno
Sent from my HTC_Amaze_4G using Tapatalk
« Reply #232 on: December 02, 2011, 10:40:50 PM »
My main concern with the Magnum Powers kit is pretty nice because it's a bolt on replacement for the JR and CT-E manifolds.  My concern is how it mounts to the manifold.  If I can reuse the mounting plate that I have for my MP62, I don't have to get an aftercooler fabricated.  If I can't then I'm going to have a new aftercooler fabricated.  Even though the MPx90 is more efficient and runs cooler at the same boost levels, I want to do everything possible to cool down the intake temps.  When winding up the MP62, my intake temps hit 250º at redline and it takes quite a bit of time for them to drop.
Rushzer0 pfffft.
« Reply #233 on: December 03, 2011, 12:22:42 AM »
E85 burns cooler if you have it in your area. Could help a little.
« Reply #234 on: December 03, 2011, 08:03:11 PM »
As a matter of fact, E85 is huge out here.  Corn growin' is a big thing out here.  I'm just not sure if I want to run E85.  I may have them do 2 tunes.  One for pump gas and one for E85.  I'd like to be able to drive my car around and not be tied to the area I live in because of the gas I use.
Reputation Power: 10
NVA-AV6 pfffft.
« Reply #235 on: December 04, 2011, 09:10:22 AM »
Your main fule lines are NOT rated for E85 and will eventually develop holes......
« Reply #236 on: December 04, 2011, 10:08:31 AM »
That answers that question.  No E85 unless I upgrade the rest of my fuel lines.  Thanks for the info Paul.
Rushzer0 pfffft.
« Reply #237 on: December 04, 2011, 10:49:45 AM »
I thought you had upgraded fuel lines already? Do our accords have a stock return fuel setup? If not do you plan on adding one? It would be much easier on your injectors as their duty cycle could be lower.
« Reply #238 on: December 05, 2011, 12:47:24 AM »
No, our Accords do not have a stock return line.  I have a fuel pressure regulator with a return line.  The stock fuel line was re-used in this set up also.  There's really no need to get rid of the stock fuel line.  It's just more work and more expensive.  I'd only replace the stock fuel line if it was damaged.
« Reply #239 on: January 03, 2012, 09:16:48 PM »
Drove to Indiana to ERL Performance today to drop my block off.  I decided to go with their I2 Turbo Race package with 11.1:1 CP pistons instead of the 9.0:1 CP pistons.  I was planning on going with Wiseco 10.5:1 pistons, but Seth at ERL said that CP would be slightly better and the difference in compression ratio would still be safe for pump gas.  In about 12 weeks I'll be very happy and sad.  Happy that I'll be getting a freshly built short block from ERL Performance.  Sad that I'll be emptying my bank account.
I also got a set of Ferea valve guides.  Time to do a light port on the head to clean up the cast slag and then have the valve guides replaced and a 3 angle valve job done by a machine shop.  Then I can start gathering valvetrain parts and start assembling the head.
Pages: « First < Previous 1 ... 14 15 [16] 17 18 ... 39 Next > Last »   Go Up
