March 17, 2026, 04:58:35 AM
Pages: « First < Previous 1 2 [3] 4 5 ... 8 Next > Last »   Go Down
Author Topic: Gen7 J30 Bolt On list  (Read 101927 times)
« Reply #30 on: February 25, 2009, 10:05:20 AM »
I will add ralco pullies to the list tonight when I get home nice find!
« Reply #31 on: February 25, 2009, 10:21:14 AM »
so its pretty good i guess? i know they make them for kseries too and i think somebody has them. im thinking to get them
price is deff good. maybe ill send him offer in couple days
Reputation Power: 10
NVA-AV6 pfffft.
« Reply #32 on: February 25, 2009, 10:21:18 AM »
IMO- The definition of bolt-on is exactly that, it is Bolt-on, so the line IMO between a bolt-on and a non-bolt-on would be machining ,fabrication, welding, or secondary tuning requried.
« Reply #33 on: February 25, 2009, 12:27:43 PM »
so pullies is not bolt on?
NVA-AV6 pfffft.
« Reply #34 on: February 25, 2009, 02:17:25 PM »
Do you bolt them on without having to do any machining or fab work, yes, so they would be bolt on....
« Reply #35 on: February 25, 2009, 06:30:45 PM »
Do you consider cams bolt ons Paul?
NVA-AV6 pfffft.
« Reply #36 on: February 25, 2009, 06:53:35 PM »
As long as there is no machining involved, in other words if you are doing lets say a TL-S cam swap on a V6 where you do not need to mess with the springs or remove the head(s), yeah, that is a bolt on. Now if you were putting in say Skunk stage 2 or 3 cams into a I4 where you really need to upgrade the springs as well and should actually pull the head to do so and then of course while you at it get the valves re-seated, then no.
lilmalu
lilmalu pfffft.
« Reply #37 on: March 09, 2009, 01:20:04 PM »
What about the J-pipe?
Milan pfffft.
« Reply #38 on: March 09, 2009, 01:50:41 PM »
Quote from: "Ryann84425"
Quote from: "Abailey4"
Richie's J pipe an Tls cams? The cams may come if you upgrade past the J30 though. Cant remember.
you can put the cams on the J30, which I will be doing very soon  :twisted:  but of course it'll help more significantly if you did go past J30.
The J-pipe should be on the list if cat-back exhausts are on there.  Just had one installed on Gen's coupe and it must be one of the best bangs for the buck.
What do you mean when you say go past J30?  Do you mean displacement?
« Reply #39 on: March 11, 2009, 08:55:17 AM »
My thought is that the J pipe is a custom part. But if you want it list under "Riches J-Pipe" I'll add it.
« Reply #40 on: March 11, 2009, 11:14:28 PM »
The It may by a custom part, but it is a bolt on part. OBX makes the same J-pipe if you would like to add that on.
« Reply #41 on: March 11, 2009, 11:25:03 PM »
Quote from: "Milan"
yes, displacement wise. Paul can turn a J30 to a J33-J37, depending on the size of your budget.
« Reply #42 on: March 12, 2009, 08:44:40 AM »
Ryan I'm pretty sure the J30 block can only be turned into the J33, and J34, and the block needs to be changed beyond that.
05AccordV6 pfffft.
« Reply #43 on: March 13, 2009, 01:01:24 PM »
Quote from: "MyNameIsThien"
Its a production piece its RV6P J-pipe and test pipe, I think he has sold over 50 units to date.  Also the OBX unit doesn't fit well, or at all in some cases.  I consider the Rv6-P J-pipe and test pipe a bolt on considering you literally have to remove 12 bolts, lol.  Also IMHO its the best bang for your buck mod out there. ($345 shipped, added gobs of mid range TQ and HP, better than the CAI for around the same price.
« Reply #44 on: March 13, 2009, 01:08:34 PM »
I dropped this in the other section at least for now!!!
Pages: « First < Previous 1 2 [3] 4 5 ... 8 Next > Last »   Go Up
