March 22, 2026, 07:01:41 AM
Author Topic: S2000 Cluster retrofit  (Read 31986 times)
Paulius005 pfffft.
« Reply #15 on: June 17, 2009, 11:56:59 AM »
It may also be a good idea to put in high temp vynil in the speedo if you want to change the colors...
Paulius San Jose, CA
kSchwiggy
kSchwiggy pfffft.
« Reply #16 on: June 17, 2009, 12:43:16 PM »
actually i just went to staples ang bought some plastic folders that i cut up to make the color panel in the speedo... i'll probably upgrade it to some higher quality photo gels later. but the cluster is backlit via LEDs now, so it doesnt heat up much at all
kSchwiggy
kSchwiggy pfffft.
« Reply #17 on: June 22, 2009, 11:23:17 AM »
after rough sanding with 60 grit and some grinding wth the dremel..
fiberglass matt laid
next: 2 types of bondo and lottss of sanding... then paint!
kSchwiggy
kSchwiggy pfffft.
« Reply #18 on: June 24, 2009, 01:34:37 PM »
bondo-ing and sanding... way more pictures than necessary but here goes anyway
since that last picture i got a lot more sanding done at home with the 220grit.... one i completely sand it with that i should just need to slap on some finishing compound and paint her up
« Reply #19 on: June 24, 2009, 01:58:23 PM »
It's coming together!
Icebox pfffft.
« Reply #20 on: June 24, 2009, 02:16:58 PM »
nice work kai, i cant wait to see the finished product
« Reply #21 on: June 24, 2009, 02:48:48 PM »
Can't wait to see how this turns out.  More pictures than necessary are appreciated.
Lemonjelly
Lemonjelly pfffft.
« Reply #22 on: June 24, 2009, 03:13:50 PM »
this is amazing! I cannot wait to see the finished product.
+1 to what time said The more pics the better!!!
Steve - NECM #4
« Reply #23 on: June 24, 2009, 03:24:10 PM »
I wonder if you could replace all the LEDs for the speedometer to a different color...
unclejud49348
unclejud49348 pfffft.
« Reply #24 on: July 01, 2009, 08:47:18 PM »
Congrats on a cool project. It looks like it's coming together very well. Keep us all updated, and dont forget to write a DIY, lol.
Justin - NHBP Sedan 5AT
(^^ Made by Milan, thanks!)
kSchwiggy
kSchwiggy pfffft.
« Reply #25 on: July 08, 2009, 11:22:08 AM »
original post updated
« Last Edit: July 09, 2009, 11:23:23 AM by kSchwiggy » Logged
« Reply #26 on: July 08, 2009, 11:42:32 AM »
Nice! Why do you have two odometers? Wasn't it something about the integrated one not being compatible?
kSchwiggy
kSchwiggy pfffft.
« Reply #27 on: July 08, 2009, 11:48:46 AM »
ahhhh i forgot to mention... the s2k odomoter will be blacked out by just using electrical tape over the backlighting for it beneath the s2k cluster glass. i totally forgot to do that thanks for reminding me. the accord odometer is more accurate due to minor errors in the speedo converter box.. and i will also still have my outdoor temp display with the accord odometer
Icebox pfffft.
« Reply #28 on: July 08, 2009, 11:54:47 AM »
are you goin to work up a diy?
« Reply #29 on: July 08, 2009, 11:55:54 AM »
Not bad.  I'm glad to see that you'll be re-working in the future.  I noticed the imperfections you mentioned.  Those shouldn't be too hard to fix though.  A little time sanding should get everything perfectly smooth and pretty.
