June 25, 2026, 08:30:03 PM
Author Topic: Extended wheel studs???  (Read 10504 times)
ADI
ADI pfffft.
« on: June 11, 2009, 12:18:02 PM »
im guna be replacing the oem studs with ARP extended studs this weekend...has anybody replaced their studs on their 7th gen?? do u just hammer the old ones out?? or is it much more involved then that?
Thanks
« Reply #1 on: June 11, 2009, 12:28:37 PM »
If you have the proper tools, the job is relatively easy.
ADI
ADI pfffft.
« Reply #2 on: June 11, 2009, 12:39:24 PM »
Quote from: "MyNameIsThien"
what are the proper tools?
any tips/procedures 2 making the job easier?
« Reply #3 on: June 11, 2009, 12:46:59 PM »
Having an impact gun will make the job a lot easier. Also, you will need a stud puller tool. You can hammer out the old ones, and slide the new one in. Put some lubricant around the stud base and the stud hole. I haven't replaced front studs on our Accords yet, but I had to on a 7th Gen Civic. I had to pull the whole hub assembly out a tad to slide an OE stud. I think the Accords has more room so you might be able to get away with it.
ADI
ADI pfffft.
« Reply #4 on: June 11, 2009, 12:53:43 PM »
i do have an impact gun, and i will make sure i have a stud puller as well.
Thanks Thien,
« Reply #5 on: June 14, 2009, 05:00:08 PM »
I have replaced a stud on the front of my Accord and you do need to pull the hub assembly out for more clearance.
macanic
macanic pfffft.
« Reply #6 on: June 14, 2009, 07:57:23 PM »
or you can take the hub assembly off and go have them pressed in..
-CORY- MDVACM #18
« Reply #7 on: June 14, 2009, 08:01:53 PM »
Either way, you have to take or pull the hub assembly. If you take the hub assembly out, you have to replace the hub bearing. You are not suppose to re-use the old hub bearing.
« Reply #8 on: June 14, 2009, 08:34:17 PM »
You can also grind the edge of the flange on the stud a little bit to also get the clearance you need.
ADI
ADI pfffft.
« Reply #9 on: June 15, 2009, 12:46:32 PM »
thanks again thien, tim and every one else that chimed in.
i thought i would be a simple thing do, something i might be able to tackle but i really don't have a lot experience when it comes to suspension components so i think im just guna leave it to professionals and take it to a shop.
thanks
