August 11, 2026, 01:13:54 AM
Pages: « First 1 [2] 3 4 ... 10 Next > Last »   Go Down
Author Topic: Master List Of Suspension Upgrades  (Read 132625 times)
« Reply #15 on: February 24, 2009, 01:13:08 PM »
Quote from: "lilmalu"
I just realized this list was updated.....gotta start the search now
Thien did a pretty good job of updating it last night.
jobata23
jobata23 pfffft.
« Reply #16 on: February 24, 2009, 04:51:45 PM »
good stuff tim, this is very helpful for anyone, considering suspension upgrade
rjp6262
rjp6262 pfffft.
« Reply #17 on: February 24, 2009, 08:55:38 PM »
those are the chassis braces! i was trying to figure out who made em for the TSX. nice!
« Reply #18 on: February 24, 2009, 09:13:21 PM »
NRG innovations also makes TQ damperers for our rides, thats what me and abailey4 are running on.
seththekorean
seththekorean pfffft.
« Reply #19 on: April 11, 2009, 10:24:43 AM »
http://www.jhpusa.com/store/pc/viewPrd. ... oduct=4316
I know its expensive, but its a TSX front camber kit from Skunk2, will it work?
It would probably be more logical to buy an ingalls or something made for our car, but just to see  if it would i had to ask.
[size=150]Seth[/size]
04' Coupe k24a4 5AT
SECM Squad Member
Rustywaffle
Rustywaffle pfffft.
« Reply #20 on: April 11, 2009, 11:20:59 AM »
Quote from: "seththekorean"
http://www.jhpusa.com/store/pc/viewPrd.asp?idproduct=4316
nice find... it should work.... i know for sure the ball joint for the tsx and our car is the same.
« Reply #21 on: April 11, 2009, 11:43:09 AM »
Those look nice, but they are pretty expensive.  You're better off getting a new set of OEM upper control arms and an Ingalls front camber kit.
Reputation Power: 10
05AccordV6 pfffft.
« Reply #22 on: April 23, 2009, 12:40:17 PM »
Won't the Skunk 2's provide more adjustability for the weekend/road racer, also I'm guessing caster and toe can be adjusted by these, though correct me if I'm wrong though.  These may be my next component so I can make day off adjustments as I plan to road race the accord this summer.
05AccordV6 pfffft.
« Reply #23 on: April 23, 2009, 12:41:37 PM »
Quote from: "rjp6262"
Good luck finding the Type II, they are sold out nationwide right now, the Type I's are scarce as well, though I did manage to procure one.
« Reply #24 on: April 23, 2009, 02:45:50 PM »
Caster and toe will probably not be adjustable from the coilovers themselves.  You would use your factory adjustments for that.  Thien can clarify this though.
« Reply #25 on: April 24, 2009, 12:21:15 AM »
Coilovers cannot adjust caster or toe. Coilovers can only adjust camber, but camber does affect toe. Now, the Skunk2 do not have camber plates to adjust camber on them. So, camber cannot be adjust through the coilovers. Now, we do have SLA front struts. SLA meaning that our struts are connected to the lower control arm instead of being connected to the knuckle. That means coilovers will more and likely won't adjust camber no matter if it comes with a camber plate or not.
Asim pfffft.
« Reply #26 on: April 24, 2009, 01:07:25 PM »
I assume best bang for buck coilovers are Tein Basics?
What I really want is a setup that is adjustable (height + camber, and maybe the damping also) for a decent price (Basics seem to be around 1000-1200 CDN)
« Reply #27 on: April 24, 2009, 04:49:21 PM »
If you want height and damper adjustment, then you should consider the Tein SS or SS-P instead of the Basics.  No matter what suspension you buy, you must buy a camber kit.  No aftermarket coil over can adjust camber, only a camber kit can do that.
Asim pfffft.
« Reply #28 on: April 24, 2009, 10:38:35 PM »
Ah righteous. I had thought some kits came with a camber kit also.
Asim pfffft.
« Reply #29 on: April 26, 2009, 12:19:30 AM »
Shouldn't the neuspeed supercup kit be up on here?
It seems like a good deal, has height adjustability (albeit not as much as a coilver)
Pages: « First 1 [2] 3 4 ... 10 Next > Last »   Go Up
