August 10, 2026, 12:57:07 AM
Pages: « First < Previous 1 ... 8 9 [10]   Go Down
Author Topic: Master List Of Suspension Upgrades  (Read 132575 times)
« Reply #135 on: March 10, 2013, 11:23:45 PM »
Unless you go super slammed, you won't need a camber kit. I was about 0 finger gap front and 1 finger gap rear. My camber spec up front is right at spec which is -0.8. You can safely run -1.0 degree of camber without causing any tire wear. Anything more, you will need a front camber kit.
06RockHead
06RockHead pfffft.
« Reply #136 on: March 10, 2013, 11:38:48 PM »
Ok ya I'm not going quite that low. So the caster on the car isn't positive enough to cause much significant change in camber with the height adjustment.
Milan pfffft.
« Reply #137 on: March 11, 2013, 09:23:16 AM »
If you don't plan on dropping more than 2.5" you should be good.  Even if you do go lower, just get your toe aligned properly and you shouldn't have any major tire-wearing issues.
« Reply #138 on: January 27, 2014, 12:49:22 PM »
This just got posted on fb in one of the Accord groups: http://www.hybrid-racing.com/store/ingalls-adjustable-upper-control-arm-04-08-tsx-03-07-accord.html
Does anyone have any info on these?
« Reply #139 on: January 27, 2014, 04:59:26 PM »
No! Lol. Looks similar to the skunk2 design which im not a fan of. Slotted holes for suspension adjustments means it may work loose over time. Also, with the heads of the screws on top would be be prone to rust easier then even the skunk2 design.
« Reply #140 on: January 28, 2014, 11:59:26 AM »
You may want to call Ingalls or Hybrid Racing about those.  It seems that there is not much information about those yet.
bian.yy
bian.yy pfffft.
« Reply #141 on: October 16, 2015, 04:50:11 AM »
I got a list somewhere for sway from TL-S sway bars as below:
51300-SEP-A21 - SPRING, FR. STABILIZER - 1x
51306-SEP-A01 - BUSH, FR. STABILIZER HOLDER - 2x
51308-SDA-A00 - BRACKET, FR. STABILIZER - 2x
52300-SEP-A11 - SPRING, RR. STABILIZER - 1x
52308-S3M-A00 - HOLDER - 2x
52306-SEP-A11 - BUSH, RR. STABILIZER HOLDER - 2x
The local dealer give a list which he can find is:
 51300-SEP-A31
 51306-SEP-A01
 51308-SDA-A00
 52300-SEP-A21
 52308-S3M-A00
 52306-SEP-A21
I'm not sure if this is ok or not, I heard somewhere 51300-SEP-A21 is for 04-06 TL-S and 51300-SEP-A31 is for 07 and 08, I'm not sure the other parts are like the same or not.
Cheers!
« Last Edit: October 16, 2015, 04:52:26 AM by bian.yy » Logged
« Reply #142 on: October 22, 2015, 10:46:49 AM »
Has anyone tried the new Tanabe Pro CR Coilover Kit?
For a while now, I've been contemplating buying the Tein Comfort Sport coilovers since I'm looking for a more comfortable ride, but the $1.6k price is holding me back.  This new Tanabe kit is half that price.  Anyone have these coils?
Evasive Motorsports - $841.50
« Reply #143 on: October 22, 2015, 02:30:25 PM »
What's the spring rate on those guys? I have the comfort sports and I've really enjoyed their ride quality. Not stiff or bouncy at all. Compare the spring rate of the Comfort Sports to the Tanabes.
« Reply #144 on: October 23, 2015, 07:22:03 AM »
Tanabe - Spring Rates (F/R): 8.0 / 4.0
Tein CS - Spring Rates (F/R): 7.0 / 4.0
Pretty close.  How do you like the CS?  Have you had other suspension setups to compare them to?
After 8 years, I'm getting tired of a bone-jarringly stiff ride.  I don't want to give up that lowered look though.
« Reply #145 on: October 23, 2015, 08:50:16 AM »
I've had the Tein Basics before the Comfort Sports. I like the ride comfort of the Comfort Sports. They are comfortable, but not stiff of bouncy.
Pages: « First < Previous 1 ... 8 9 [10]   Go Up
